  New Posts New Posts RSS Feed - heat smell
heat smell
Guests View Drop Down
Guest
Guest
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: heat smell
    Posted: 01 May 2007 at 10:44pm
hey guys sorry with all the questions but i ahve another question, but wen i use my heat or turn the dial to like warm or hot, it smells wat do u think it is? i have 1986 pontiac fiero gt fastback
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2007 at 11:56pm
Probably a leaking heater core.  Keep an eye on your water level in the cooling system.
If the car is A/C it is very easy to change, if the car does not have AC it is a bit more work, but still very easy.  In either case, a mechanic will take less than an hour to do it.
Guest
Guest
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2007 at 11:56pm
i got a new ehater core put in adn everythign only wen i use the warm air it does it
Post Options Post Options   Quote beken Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2007 at 10:30pm
If you had just replaced your heater core, it is possible some coolant got spilled into the venting.   Hence when you turn on the heat, the smell of the coolant gets blown into the cabin.
On the other hand, the heater core swivels to open and shut the vent (heat exchange) and the coolant in the core is connected to the cooling system via rubber hoses.  It is possible those hoses need replacing also.
Good luck with it....
Blair View Drop Down
Post Options Post Options   Quote Blair Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2007 at 6:05am
When I first got my GT it smelled of antifreeze. I changed the heater core only to find out that the core had already been changed. For the next 2 years I could smell antifreeze when the heater was on. I assume that antifreeze had gone into the vents and the residue is what I was smelling.
Unless you took the heater apart and cleaned it when the heater core was replaced this could be the problem.
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2007 at 8:30pm
Another thought - this person never actually said 'smells antifreeze'!
Are you smelling that, or mold, or a dead herring, or......   ????
Guest
Guest
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2007 at 12:18am
i dont think its antifreeze i think its liek mold or mildew or sumthin
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2007 at 7:03am
Hit up your local auto parts place.
There's stuff you can get in a spray can that is for cleaning out mold in air conditioning systems.  You spray it down your air intake (usually with all the doors and windows closed, A/C on high - NOBODY in the car!!!!).
The air intake is got to by popping the front hood - look right around the passenger side windshield wiper - see the vent/grill?  Just put your hand there with the fan on high and you'll feel it sucking in.
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2007 at 6:35pm
John do you think that will help with the musty, stale air smell usually associated with A/C systems.
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2007 at 8:22pm
Yes - that's what the stuff is intended for.
Kills the mold spores that cause the smell.
