Front air suspension build, how to |
Fire451 ![]() Senior Member ![]() ![]() Joined: 14 February 2007 Location: Canada Status: Offline Points: 318 |
![]() ![]() ![]() ![]() Posted: 17 July 2010 at 4:48pm |
well there have been some questions as to how to do a front air suspension in a fiero and I have been ablr to build one up that still has the ability to use the sway bar.. First remove your stock front springs, spindles etc... next you are going to have to drill out the 4 rivits that hold the lower spring bucket in place you should end up with this and you will then have to cut the lower bucket like this you will have to cut out your bump stop and the bump on the lower control arm the next step is to cut and weld in the upper air bag mount the lower bucket needs this lip removed like this the lower mount can be bolted in with some 5/16" bolts and then you can mock up and tack the previously bought air bag mounting plate, pull out and weld, make sure your air bag is as straight as possiable. then clean up, paint and bolt it all back togeather plumb you air, bolt on the rest of the stock suspension, brakes, wheel and enjoy |
WOW thats a tone of work, looking great though.
Holy eff, that is an amazing amount of customization you did there. Good luck with the rest of the build!
suprisingly it only took about 4 hours / side which actually flew by, well the first side took a little longer as I was tring to figure out how to go about doing it. Now all I need to get it the 2 fittings that I didn't get (thought I had thought of every possiable one that I would need) and put it back togeather and test it out, there will be a video of that once it happens
well here are a couple of pics: no air full air (sorta) compressor was getting low at this point
Looks Great. Can't wait to see it in motion as you are driving down the road. Just might want to put a stopper of some sort so that it can't bottom out the tire while driving.
Very cool:)...
Slammin'!
Looks good! I see you're able to continue to use the front shocks. Perhaps I'm jumping ahead here, but what are you going to use as dampers in the back? [EDIT] I found the answer on page 2 of your other thread. |
