  New Posts New Posts RSS Feed - Front Brake Issue
Front Brake Issue
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 16 February 2010 at 12:01am
Besides Patty, I've been applying the lubricant I was told to in every shop I've ever worked in, doesn't mean I knew the name of what I was using.
But again, can you at least point out where your concern stems from? What do you expect to go wrong from lubrication of the slide pins?
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 16 February 2010 at 12:02am
I constantly use products to accomplish tasks they were never designed for.  It's called "thinking out of the box."
When it works, it's referred to as "thinking out of the box".
When it doesn't work, well, there are a lot of neat phrases that could describe that as well.
I don't understand why you are so reluctant to supply any info on the specific product you mentioned that you use. I googled and can't find much of anything on "Never Seize".
I use a product called Never Seize.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 16 February 2010 at 12:08am
What do you expect to go wrong from improper lubrication of the slide pins?
Fixed that for you.
You're the one training to be a mechanic. You should be able to tell me.
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 16 February 2010 at 12:18am
Because it's erelevant.
I understand the properties of the base materials and have over 20 years of practical experience with this product.
Anyhow, we've beaten that poor horse to a pulp.  Unless you have something tangible to base you opinions on I don't see much point in continuing this thread.
[QUOTE=Dawg]I use a product called Never Seize.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 16 February 2010 at 12:39am
You feel it's "erelevant" to supply basic background information on a product you're promoting for use on brake components??
Fine, there's not much point discussing this any further then.
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 16 February 2010 at 12:57am
Fixed that for you.
I fail to see what you mean by "improper" lubrication. Like I had said, anything non-abrasive will work fine, provided you don't go balls-out with how much you put on. It really is a challenge to try and do improperly...
Roadfury View Drop Down
Post Options Post Options   Quote Roadfury Quote  Post ReplyReply Direct Link To This Post Posted: 16 February 2010 at 9:46pm
Technically your both wrong :D
and technically your both right.
Next time I do a brake job I'll probably use Anti-Seize again just because I've got loads of it here.
Plus:
It's copper anti-seize so the metal particles in it, theoretically, since steel is hrder then copper there should be no damage. (for example, if you take a piece of wood and try to cut through a bar of metal, its not going to happen.
It's petroleum based so it is hard on o-rings, but when I pulled the pins out I saw no o-rings in the pins. The only o-ring i saw was on the piston which i didn't anti-seize. I could be wrong, I dont know, could someone confirm this?
Also, other than people saying "don't do this" tech specs saying "use this other stuff" there hasn't really been any real reason why you cant use anti-seize.
Not using anti-seize would be good though because,
there is probably a good reason why manufactures don't want you to use it, (possible because silicon is cheaper to make than copper based anti-seize )
The petroleum based lube can in theory break down dust boots and o-rings.
Here's a site saying why you shouldn't use it
http://www.guzzle7pt3.com/cu.php
(about halfway down)
and here's the site directly contradicting that
http://www.sealanddesign.com/category/7/Loctite/page/104/Lub ricating/cpage/49/Anti_Seize.aspx
Until someone shows me a petroleum rotted (possibly mythical) caliper slide-o-ring or boot, i'll stick to anti-seize
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 16 February 2010 at 11:13pm
If your caliper sliders aren't riding on O-rings, you've got bigger problems than just what lubricant you've used.
http://www.sealanddesign.com/category/7/Loctite/page/104/Lub %20ricating/cpage/49/Anti_Seize.aspx
I see nothing on that page relating to lubrication of caliper sliders.
...i'll stick to anti-seize
Was that a pun?
I wanted to hear what the collective brain trust of Pennock's Fiero Forum had to say about this topic. See the resulting discussion Here.
Post Options Post Options   Quote Roadfury Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2010 at 5:42am
Where are they located though? thats what im asking.
No i didn't say that it did, The link before that one says to use silicon stuff because the anti-seize "can't handle the high temps" and the info on the above link says its specifically for high temp applications.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2010 at 11:33am
The pin of the caliper sliders goes through a bore in the calipers. At either end of this bore is a rubber O-ring. The area between the O-rings is supposed to be packed with lubricant when being serviced. I don't know how you could not notice the O-rings when you were cleaning and lubricating this area.
