  New Posts New Posts RSS Feed - Hard Starting v6 fiero
Rickrose21 View Drop Down
Post Options Post Options   Quote Rickrose21 Quote  Post ReplyReply Direct Link To This Post Topic: Hard Starting v6 fiero
    Posted: 12 April 2010 at 12:36pm
Hi, anyone know what could cause my fiero to have long start times?  I am not sure what this could be, injectors? fuel pump? plugs? wires? distibutor? any suggestions would be much appreciated.  Thanks
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2010 at 1:26pm
Make any difference whether the engine is cold or hot?
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2010 at 2:06pm
Leaking injectors, weak ignition, really old engine with bad rings causing loss of compression, lots of reasons.
Post Options Post Options   Quote Rickrose21 Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2010 at 5:25pm
If the engine is running, it idles a little rougher than my other one, but it only has 128000km on it and starts up first crank if i turn it off then start it again right away, could a fuel pressure regulator be the cause also?  the exhaust seems to be running rich as there is quite the strong gas/exhaust smell from it.  HELP
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2010 at 7:33pm
Really dirty fuel filter could cause this and it's easy to try.
Post Options Post Options   Quote Rickrose21 Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2010 at 7:49pm
just changed the fuel filter about 2 months ago,
