Temp gauge "poll" |
![]() ![]() ![]() ![]() Posted: 31 January 2010 at 9:22am |
(that's not really a poll!)
IF you think your temperature gauge is accurate (or really close) - my question is, when the engine is cold (let's say it's been sitting for at least 8hrs), and it's about 10-15C outside, WHERE does your temp needle point when you first turn the key on. Right at the '40'? Just below? Other? |
Mine sits below 40, and never, ever vacates that spot. I fear my gauge may have an issue or two.
35 views, and only one (who's gauge doesn't even work!) response??
Just turn your key to "on". Where does your needle sit! |
88FieroGT ![]() Member ![]() ![]() Joined: 24 March 2007 Location: Canada Status: Offline Points: 78 |
Mine sits about 2mm below the "40" mark when I turn the key
wayneh70 ![]() Member ![]() ![]() Joined: 09 May 2009 Location: Canada Status: Offline Points: 52 |
Same here, just below the '40'
rumonk ![]() Newbie ![]() Joined: 26 October 2009 Location: Canada Status: Offline Points: 41 |
mine sits just below 40 as well
