  New Posts New Posts RSS Feed - Adjustable Thermostat
Post Options Post Options   Quote ARTIC-1 Quote  Post ReplyReply Direct Link To This Post Topic: Adjustable Thermostat
    Posted: 12 July 2011 at 10:11pm
No need to change your Thermostat,just put one of these puppys in an dial it in,160-165-170-180-190-200-210?what ever you like.$40 @ lordco
http://www.hotrodexpress.com/index.php?l=product_detail& p=245
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Posted: 13 July 2011 at 8:58am
Wow...something to consider
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 13 July 2011 at 10:43am
Seriously though, with a properly functioning cooling system, what's the need to make the thermostat adjustable?
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 14 July 2011 at 8:42am
You can let it run warmer for daily driving (Mileage) and colder for racing (Power/Safety). Would be my guess, anyways.
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 14 July 2011 at 11:34am
The thing in that picture doesn't seem to be able to do that.  It looks like a fan switch not an internal thermostat.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 14 July 2011 at 12:00pm
That's exactly what it's listed under... Fan Controllers/Sensors.
Post Options Post Options   Quote ARTIC-1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 July 2011 at 4:55pm
You guys are vary much right,all it does is turn the fan on an off.its not a Adjustable internal thermostat.But with being able to dial it in to come on @ a lower temp,your volume of cooling will be a lower temp returning to the motor.
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 14 July 2011 at 9:47pm
That would be OK if your thermostat did not close the circulation and stop the water flow making the rad fan run for nothing.
         It is a nice mod if you just want to reduce the turn on fan temp slightly lower than stock but not below say 190f ON temp, or better yet if you wanted it to control some engine bay fans.  Getting cool air over the intake will be more of a benefit than running the water cooler.
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 14 July 2011 at 9:57pm
Dave has the right idea for sure.  I would take that thing and hook it up to fans in the engine compartment.
I've been thinking of doing this myself.
