WTD Clear Fiero Stickers |
Page <12 |
One of the things I would research more is how a flat surface on a brake caliper would disipate heat and resist warping.
New brakes seem to have fins cast into parts of it to allow more surface area for heat disipation. Curved surfaces, if I remember my physics correctly, have larger surface areas. Also cast metal with curved surfaces, particularly if thicker in the middle, are less likely to warp. A totally flat surface with even thickness can warp due to temperature changes, unless you have areas where heat expansion of the metal can move to and return from. Alternatively, some big brake kits (Willwood, Brembo etc) have a flat surface because they have fins mounted underneath as well as 3 or more pistons (as opposed to one or two in most OEM applications). Note that the flat surface is on top of something very thick, which might give you some offset issues. The MINI's JCW brake kit are actually two piston Brembos with the JCW logo printed on the curved surface. ![]() |
Yes, the heat dissapation is what has me concerned (Not so much the offset, the sheet will be thin). There is still fins on the underside of the flat piece, however there wont be much, if any, airflow to them, making convection negligable. Will have to look into some heating characteristics prior to going nuts.
I honestly don't belive any decal or sticker will last more than 30 days on a caliper, they just get way too hot.
Yeah, that is logical... I do believe it was Chris who suggested stencling in a black painted one instead, which would look very classy. |
Page <12 |
