WTD: manual swap parts (F23) |
![]() ![]() ![]() ![]() Posted: 12 December 2011 at 8:26am |
I need some parts for my f23 swap. and by "some" I mean pretty much
everything an auto wouldn't have. So if anyone has something they no longer need or a good source let me know. What I still need: Clutch switch connector Mounts? Clutch Flywheel Pressure plate deckid torsion bars Already got: Shift cables Shifter Center console Axles Clutch pedal Brake pedal Clutch line The trans itself I will get from pick a part unless someone knows a better source. |
Anybody have the connector that plugs into the clutch switch? I have the switch itself, but no way of plugging the wires into it.
Also, the little clips that hold the shift cables into the brackets, I need 3 more, only one on the auto was the right size. Those are the last pieces I need to get the interior back together. Let me know, Thanks |
For those that have done manual 3800 swaps, where did you get your flywheel? I have heard bad things about the cheap aftermarket brands being porous once machined, and don't wanna spend hundreds on an aluminum one.
finallall ![]() Newbie ![]() Joined: 24 October 2010 Location: Canada Status: Offline Points: 1 |
I got mine from West Coast Fieros. I took over 1 month to
get here (Edmonton) but it's a quality unit and cost me lass then $300. |
$300 is a little too steep for me right now.
Looks like I need some decklid torsion bars ![]() |
As long as the fenders don't fall off during the night, you're good...:)
